I need to open up my keyboard since one led is not lighting up. I don't want to RMA since it'll take 4-6weeks and I don't have a decent keyboard.
Anyone have ideas how to open this up? The farthest I have tried is removing 4 screws from the bottom of the board. I'm not sure if there are a couple more though.
Razer Blackwidow Disassembly Guide?
- Main keyboard: Blackwidow Ultimate
How do I access those two? Just pop off the cover?sixty wrote:There are 6 screws in total. One in each of the 4 corners under the rubber feet, and then 2 more under small plastic parts near the cable.
Thanks will do!sixty wrote:Yes, just pop it off with your fingernail or a small screwdriver.
However, I noticed that the LED on the key is lighting up again.
