Springs
Where do I find some springs for cherry switches. I'm looking for 45grams springs (those of cherry reds). Maybe something from sprit? Someone here wrote that those springs feel very different from the cherry ones. Any experience with the massdrop ones? Any way the drop has ended.
- DanielT
- Un petit village gaulois d'Armorique…
- Main keyboard: Various custom 60%'s/HHKB
- Main mouse: MS Optical Mouse 200
- Favorite switch: Topre/Linear MX
Here you can find some 62/65g springs http://leandren.bigcartel.com/product/s ... ld-springs
Unfortunately SPRiT si gone MIA now, he was a very good source for springs. I have some 50g gold springs which are as light as MX Red but they are back home
- flabbergast
- DT Pro Member: 0120
Just a quick note - the Korean way of weighting the springs is different from Cherry MX - the Korean ones are measured fully squashed, while the MX are usually given at the point of actuation (about half-way pressed). I think the Korean 55g ones are about the same as 45g Cherry reds.
- DanielT
Yep, that is correct. 50g Korean style are lighter than MX Red , 55 from SPRiT are almost the same but a little more elastic, the feel is way better.flabbergast wrote: Just a quick note - the Korean way of weighting the springs is different from Cherry MX - the Korean ones are measured fully squashed, while the MX are usually given at the point of actuation (about half-way pressed). I think the Korean 55g ones are about the same as 45g Cherry reds.
So sprit is disappeared...
I've found some springs on
http://winkeyless.kr/product/custom-spring/
There are 55grams ones, which should be more or less like a 45 grams springs... Hope that the delivery is cheap...
