[IC] Tai Hao ISO key sets (UK Based)
- joekenton
- Main keyboard: Poker X
- Main mouse: Gigabyte
- Favorite switch: Not Sure
Hi,
I'm primarily a r/mk user so this is my first post here, I am conducting an interest check for Tai Hao keycap sets in ISO layout over on Reddit.
The main info is available over there - click here to take a look
- joekenton
- joekenton
- scottc
- DT Pro Member: 0167
hmm good point i think it does but i will ask them.
There is an " extra "set for none standard layouts but i am pretty sure it does come with it out of the box
- scottc
That just bit me now, I was putting a spare Tai Hao set on an unused Cherry board and was only missing caps lock... The spacebar doesn't fit properly either, the stab holes were in a weird spot.
- scottc
Just read the GB info page:
So you'll probably need the extra £4 set. Then I read:Additional key sets are available for keyboards with non-standard layouts - These sets include:
1*Step Cap Lock
1*1x1.75 shift
2*1x1.5 Ctrl
2*1x1.5 Alt
1*1x7 Space bar
3*1x1 Blank key
and now I'm rather put off. Meh...NOTE - PBT keysets occasionally have issues such as slightly warped space bars, this is not common however if this occurs UKKeycaps is not responsible and cannot offer refunds.
yep they just added the option to upgrade so i will doh
EDIT
a slightly bent spacebar does not bother me that much. I can always pick up a black cherry spacebar cheap.
EDIT
- joekenton
Read the line under thatscottc wrote: Just read the GB info page:
1*Step Cap Lock
1*1x1.75 shift
2*1x1.5 Ctrl
2*1x1.5 Alt
1*1x7 Space bar
3*1x1 Blank key
Just worth mentioning that people have had great success heating the space bars with a hair dryer against a flat surface. I know that this shouldn't have to be the case although recently, in some of the ANSI group buys, it's happened.
Odds are they're absolutely fine and no action will be needed but just a tip
I'll be getting involved, regardless of the twonky space bar.
- joekenton
Update! MOQ has been lowered to 25 - this means only 8 orders needed to reach it!
Deadline is 27/07/15
All info on reddit thread as usual - https://www.reddit.com/r/mechmarket/com ... so_w_ansi/
EDIT: 5 Orders from MOQ, 1 week left!
