5 is yours
FSSK PCBs (1st round)
- lot_lizard
- Main keyboard: Indy SSK Model MF
- Main mouse: Logitech Anywhere MX
- Favorite switch: Beamspring
9 and 23 please...
- idollar
- i$
- Main keyboard: IBM F or M
- Favorite switch: BS
(repeated) Based on this post, I have numbered the PCBs.
Post the PCB number that you want to have or that you need in this tread.
The table with the PCB allocation has been added to the first post of the GB
The process is FIFO
The process is FIFO
- lot_lizard
So I am having my friends at a machine shop make a door flap (plastic) replacement (stainless steel) for my 3279 beamspring. On Tuesday, I pick it up. I am going to ask about having a thicker gauge stainless steel baseplate cut and bent for the FSSK (say twice as thick). I would drill and countersink the holes myself using one of my presses, and would likely have mine either painted or powder coated afterwards. I already ordered two replacement frames from Unicomp, and the hope is that I can use my 2 FSSK's as drop in full replacements (without having to even touch the other bolt mods). If others have interest in the 2X thick back plates, let me know, and I can ask about bulk builds (keep in mind this is artistic work... Not China). I$... Yours is pro bono... Just send me your address
- idollar
- i$
Guau ! I will PM you.lot_lizard wrote: So I am having my friends at a machine shop make a door flap (plastic) replacement (stainless steel) for my 3279 beamspring. On Tuesday, I pick it up. I am going to ask about having a thicker gauge stainless steel baseplate cut and bent for the FSSK (say twice as thick). I would drill and countersink the holes myself using one of my presses, and would likely have mine either painted or powder coated afterwards. I already ordered two replacement frames from Unicomp, and the hope is that I can use my 2 FSSK's as drop in full replacements (without having to even touch the other bolt mods). If others have interest in the 2X thick back plates, let me know, and I can ask about bulk builds (keep in mind this is artistic work... Not China). I$... Yours is pro bono... Just send me your address
- ramnes
- ПБТ НАВСЕГДА
- Main keyboard: KMAC LE
- Main mouse: Zowie AM
Dumb question: what is that rubber mate you're talking about? The one between the PCB and the back plate?
- idollar
- i$
I will explain it with lot of details in the "Users Manual Thread".
A quick answer is: with the FSSK 0001 (prototype) I used the rubber mate between the flippers and the M membrane between the F flippers and the PCB. This worked. The rubber mate in the second FSSK was different and would not allow the set to work if in used. As soon as it was removed the keyboard worked as a dream. It took me more than 10 tries to find this out.
- Main keyboard: Ducky Shine 3
- Main mouse: MX Revo
- Favorite switch: MX Blue
Is the #12 still available? If so, I'll take it !
- Techno Trousers
- 100,000,000 actuations
- Main keyboard: IBM Model F-122
- Main mouse: Mionix Naos
- Favorite switch: Capacitive Buckling Spring (Model F)
- DT Pro Member: 0159
If we leave out the rubber mat, does that mean we should put tape on the back plate to keep it electrically neutral?
- idollar
- i$
- idollar
- i$
Yours will be 11. And you know what they say about this number:
There are 11 types of people: the ones that can read 11, the ones that cannot and the ones that do not understand this sentence.
In reality the phrase applies with 10, I just had to adapt it a little BIT
- Hypersphere
- Main mouse: Logitech G403
- DT Pro Member: 0038
I do not need a special number. Thanks.
